A cada ts que entro me sale the time difference between server and client is too large)
First:
This is the way!
Second, translation:
Every time I enter I get “the time difference between server and client is too large”
Third, this error means that either you or server owner desynchronized clock. Please check if you set up your clock properly. If your clock is OK, then it means that server owner screwed up clock on his server. If you can, contact server owner and tell them about your problem.
If you get this error on every server, setup your clock properly (right time and time zone)!
