No sound after a while
Ihave a the mproblem that my sound stops after a while and i cant hear anyone.
i have to restart my client and then it works again but cuts out again after a while.
Happens with both clients. less often with TS3
Does this issue is just for TS or also for other software running on your computer?
Was this issue always present or was it working fine at some point?
only Teamspeak. it worked a year ago just fine. i set my devices correctly
audiodrivers are up to date and i already reinstalled teamspeak
If this problem also appears in TS3 then this is probably an issue with your current audio setup, as the client has not received an update since September of 2023.
Are you using a wireless device?
What OS are you using?
[Aktueller Computer]
[Betriebssystem]
Betriebssystem: Microsoft Windows 11 Home (x64) Build 26100.3775 (24H2)
UEFI-Start: Vorhanden
Sicherer Start: Deaktiviert
Hypervisor-geschützte Codeintegrität (HVCI): Deaktiviert
Audio ---------------------------------------------------------------------
NVIDIA GA102 - High Definition Audio Controller ---------------------------
Audioadapter: NVIDIA GA102 - High Definition Audio Controller
Hardware-ID des Audio-Controllers: PCI\VEN_10DE&DEV_1AEF&SUBSYS_403F1458&REV_A1
Hochauflösender Audiocodec: nVidia HDMI/DP
Hardware-ID des Audiocodecs: HDAUDIO\FUNC_01&VEN_10DE&DEV_009A&SUBSYS_1458403F&REV_1001
[Informationen zum Gerätetreiber]
Treiberhersteller: NVIDIA Corporation
Treiberbeschreibung: NVIDIA High Definition Audio
Treiberanbieter: NVIDIA Corporation
Treiberversion: 1.4.3.2
Treiberdatum: 28-Sep-2024
DeviceInstanceId HDAUDIO\FUNC_01&VEN_10DE&DEV_009A&SUBSYS_1458403F&REV_1001\5&39B4D188&0&0001
AMD Family 17h/19h - HD Audio Controller ----------------------------------
Audioadapter: AMD Family 17h/19h - HD Audio Controller
Hardware-ID des Audio-Controllers: PCI\VEN_1022&DEV_1487&SUBSYS_87C51043&REV_00
Hochauflösender Audiocodec: RealTek ALC S1220A
Hardware-ID des Audiocodecs: HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_104387C5&REV_1001
Treiberhersteller: Realtek Semiconductor Corp.
Treiberbeschreibung: Realtek High Definition Audio
Treiberanbieter: Realtek Semiconductor Corp.
Treiberversion: 6.0.9700.1
Treiberdatum: 25-Jun-2024
DeviceInstanceId HDAUDIO\FUNC_01&VEN_10EC&DEV_1168&SUBSYS_104387C5&REV_1001\5&1C0BA1DF&0&0001
No WirelessDevice
Could you provide me with a recent client log where you we’re able to “reproduce” this issue.
Windows power settings may also be interesting in this case.
How often do these cut outs appear?
Sorry it took me so long but i was able to reproduce the failure.
[2025-05-02 15:13:24.410] [info] Notifications_Windows ctor
[2025-05-02 15:13:24.435] [info] TeamSpeak Client 6.0.0-beta2 (2025-01-21 14:07:05)
[2025-05-02 15:13:24.435] [info] SystemInformation: Windows 11 (26100) x64 (AMD or Intel) Binary: 64bit
[2025-05-02 15:13:24.451] [warning] calling clientlib functions on uninitialized clientLib
[2025-05-02 15:13:24.752] [debug] WebSockets Server started successfully
[2025-05-02 15:13:27.181] [debug] WAS::openDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:13:27.759] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:27.759] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:27.903] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:27.903] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:27.903] [debug] WAS::openDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:13:27.903] [debug] WAS::startDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:13:27.909] [debug] WAS::startDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:13:48.587] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.590] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:13:48.590] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:13:48.679] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:13:48.679] [trace] WAS Buffer size: 1056 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:13:48.680] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.680] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.833] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.833] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.838] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:48.838] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:48.847] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:48.847] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:48.848] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:13:48.848] [info] Connecting to 62.104.20.237:10047
[2025-05-02 15:13:48.848] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:13:48.848] [info] Connecting to resolved address 62.104.20.237:10047
[2025-05-02 15:13:48.871] [info] server sent ciphers:1
[2025-05-02 15:13:48.892] [info] Selected cipher:0
[2025-05-02 15:13:48.892] [trace] Puzzle solve time: 4
[2025-05-02 15:13:54.424] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-05-02 15:13:54.958] [info] connected to push system.
[2025-05-02 15:15:27.342] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:27.342] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:27.342] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:27.342] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:27.343] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:15:27.346] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:27.346] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:27.355] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:27.355] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:27.355] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:27.356] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.451] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:31.451] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:31.452] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:31.452] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:31.453] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:15:31.456] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.456] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.463] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.463] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.464] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:31.464] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:31.474] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:15:31.474] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:15:31.476] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:15:31.476] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:15:33.483] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:33.483] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:33.483] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:33.483] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:33.484] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:15:33.487] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:33.487] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:33.495] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:33.495] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:33.495] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:33.496] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.326] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:36.327] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:36.327] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:36.327] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:36.328] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:15:36.331] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.331] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.338] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.338] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.339] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:36.339] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:15:36.353] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:15:36.353] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:15:36.359] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:15:36.359] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:15:58.846] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.846] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.846] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.846] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:58.846] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:58.846] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.846] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:58.846] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:15:58.846] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:15:58.892] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:58.892] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:15:58.893] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:15:58.893] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:15:58.893] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:15:58.893] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.896] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:15:58.896] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:15:58.974] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:15:58.974] [trace] WAS Buffer size: 1056 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:15:58.974] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:58.974] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:15:59.126] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.515] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.515] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.515] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.515] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:01.515] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:01.515] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.515] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:01.515] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:01.516] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:16:01.560] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:01.560] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:16:01.560] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.563] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:01.563] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:01.639] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:01.639] [trace] WAS Buffer size: 1056 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:01.639] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.639] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:01.794] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:21.568] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:21.568] [debug] WAS::stopDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:21.568] [debug] WAS::stopDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:21.569] [debug] WAS::closeDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:21.569] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:21.569] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:21.569] [debug] WAS::closeDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:21.569] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:21.569] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:21.569] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:16:21.575] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:21.576] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"","formFactor":11,"id":"","interfaceName":"","name":""},"error":0},"deviceListInfo":{"devices":[{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},{"description":"Realtek Digital Output","formFactor":8,"id":"{0.0.0.00000000}.{ed6e4f17-c924-4063-abbd-a36a1960c20d}","interfaceName":"Realtek(R) Audio","name":"Realtek Digital Output (Realtek(R) Audio)"}],"error":0},"io":0,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:21.576] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:16:21.589] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:21.589] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:21.597] [info] Windows Audio Session - DEVICETYPE_PLAYBACK - Default device changed: {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:16:21.597] [debug] WAS::openDevice-enter - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:16:21.602] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:21.602] [trace] Initializing with mix format. - Lautsprecher (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:21.628] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:21.628] [trace] WAS Buffer size: 1056 - Lautsprecher (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:21.628] [debug] WAS::openDevice-leave - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:16:21.629] [debug] WAS::startDevice-enter - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:16:21.630] [debug] WAS::startDevice-leave - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:16:21.631] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},"error":0},"deviceListInfo":{"devices":[{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},{"description":"Realtek Digital Output","formFactor":8,"id":"{0.0.0.00000000}.{ed6e4f17-c924-4063-abbd-a36a1960c20d}","interfaceName":"Realtek(R) Audio","name":"Realtek Digital Output (Realtek(R) Audio)"}],"error":0},"io":0,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:23.522] [info] Windows Audio Session - Device added: {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.534] [trace] Hardware agc not available - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:23.537] [trace] Hardware agc not available - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:23.537] [debug] WAS::openDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.590] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.590] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.670] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.670] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.670] [debug] WAS::openDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.670] [debug] WAS::startDevice-enter - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.672] [debug] WAS::startDevice-leave - {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.672] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},"error":0},"deviceListInfo":{"devices":[{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}","interfaceName":"Realtek(R) Audio","name":"Lautsprecher (Realtek(R) Audio)"},{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},{"description":"Realtek Digital Output","formFactor":8,"id":"{0.0.0.00000000}.{ed6e4f17-c924-4063-abbd-a36a1960c20d}","interfaceName":"Realtek(R) Audio","name":"Realtek Digital Output (Realtek(R) Audio)"}],"error":0},"io":0,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:23.673] [info] Windows Audio Session - DEVICETYPE_PLAYBACK - Default device changed: {0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}
[2025-05-02 15:16:23.673] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}","interfaceName":"Realtek(R) Audio","name":"Lautsprecher (Realtek(R) Audio)"},"error":0},"deviceListInfo":{"devices":[{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}","interfaceName":"Realtek(R) Audio","name":"Lautsprecher (Realtek(R) Audio)"},{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}","interfaceName":"Sonic Studio Virtual Mixer","name":"Lautsprecher (Sonic Studio Virtual Mixer)"},{"description":"Realtek Digital Output","formFactor":8,"id":"{0.0.0.00000000}.{ed6e4f17-c924-4063-abbd-a36a1960c20d}","interfaceName":"Realtek(R) Audio","name":"Realtek Digital Output (Realtek(R) Audio)"}],"error":0},"io":0,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:23.683] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.687] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.687] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.695] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.695] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.696] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.696] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:23.925] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.925] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.925] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.925] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.926] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:23.926] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:23.926] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:23.926] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:23.926] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:16:23.927] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:23.978] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:23.978] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:23.979] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:16:23.979] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:23.979] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:24.012] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"","formFactor":11,"id":"","interfaceName":"","name":""},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:24.012] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:24.013] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:24.015] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:24.015] [trace] Initializing with mix format. - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:24.023] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:24.023] [trace] WAS Buffer size: 1056 - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:24.023] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:24.023] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:24.024] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:24.024] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:24.024] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:24.024] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:24.215] [info] Windows Audio Session - Device needs reopening{0.0.1.00000000}.{64c5d061-a8cf-4dc7-9d68-01fa0ed22924}
[2025-05-02 15:16:25.538] [info] Windows Audio Session - Device added: {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.552] [trace] Hardware agc not available - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:16:25.554] [trace] Hardware agc not available - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:25.554] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"},{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:25.562] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.571] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.637] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:25.637] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:25.717] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:25.717] [trace] WAS Buffer size: 1056 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:16:25.717] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.717] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.876] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:25.876] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:25.876] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:25.876] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:25.876] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:16:25.876] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:16:25.876] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:16:25.877] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:25.877] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:25.877] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:16:25.879] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:25.879] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:16:25.879] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"},{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:16:29.930] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:29.934] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:29.934] [trace] Initializing with mix format. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:29.941] [info] Initialized with 2 channels in 32bit, 48kHz. - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:29.941] [trace] WAS Buffer size: 1056 - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:29.942] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:29.942] [trace] [Echo] IAudioClient::GetDevicePeriod - 10.000000ms - Lautsprecher (Realtek(R) Audio)
[2025-05-02 15:16:52.331] [debug] WAS::associateAECDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:52.332] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:52.332] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:16:52.332] [debug] WAS::associateAECDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:16:52.332] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:16:52.333] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:16:52.348] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:52.348] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:16:52.352] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:16:52.352] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:17:06.405] [error] [Capture] unknown error: AUDCLNT_E_DEVICE_INVALIDATED (0x88890004) - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:06.405] [info] Windows Audio Session - Device needs reopening{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.405] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.406] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.406] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Realtek(R) Audio) - DeviceDeleteList
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:17:06.406] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:17:06.406] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:17:06.406] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:06.409] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:06.409] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:06.418] [trace] Couldn't initialize AudioClient with given format: (0x80070005) - Zugriff verweigert - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:48.513] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:48.513] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"","formFactor":11,"id":"","interfaceName":"","name":""},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:17:48.531] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:17:48.531] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:17:48.535] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:48.535] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:48.538] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:17:48.538] [trace] Initializing with mix format. - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:17:48.546] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:17:48.547] [trace] WAS Buffer size: 1056 - Mikrofon (Sonic Studio Virtual Mixer)
[2025-05-02 15:17:48.547] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:48.547] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:48.547] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:48.547] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}","interfaceName":"Sonic Studio Virtual Mixer","name":"Mikrofon (Sonic Studio Virtual Mixer)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:17:53.668] [info] Windows Audio Session - Device removed{0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:53.668] [debug] WAS::stopDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:53.668] [debug] WAS::stopDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:53.668] [debug] WAS::closeDevice-enter - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:53.668] [trace] DeviceDeleteList::queue_device_delete - enter: Mikrofon (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:17:53.669] [trace] DeviceDeleteList::queue_device_delete - leave: Mikrofon (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:17:53.669] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:17:53.669] [debug] WAS::closeDevice-leave - {0.0.1.00000000}.{8b30a789-432e-4783-ac68-273f99118b26}
[2025-05-02 15:17:53.669] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:17:53.669] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:17:53.676] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:17:53.676] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"","formFactor":11,"id":"","interfaceName":"","name":""},"error":0},"deviceListInfo":{"devices":[],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:17:53.677] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:17:53.887] [info] Windows Audio Session - Device removed{0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:17:53.887] [debug] WAS::stopDevice-enter - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:17:53.887] [debug] WAS::stopDevice-leave - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:17:53.887] [debug] WAS::closeDevice-enter - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:17:53.887] [trace] DeviceDeleteList::queue_device_delete - enter: Lautsprecher (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:17:53.887] [trace] DeviceDeleteList::queue_device_delete - leave: Lautsprecher (Sonic Studio Virtual Mixer) - DeviceDeleteList
[2025-05-02 15:17:53.887] [trace] DeviceDeleteList::clear_queue - enter - DeviceDeleteList
[2025-05-02 15:17:53.887] [debug] WAS::closeDevice-leave - {0.0.0.00000000}.{89493abd-cee4-443e-9a4a-2d254b2a1cb9}
[2025-05-02 15:17:53.887] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 15:17:53.888] [trace] Waiting for device to close  - DeviceDeleteList
[2025-05-02 15:17:53.889] [trace] DeviceDeleteList::clear_queue - leave  - DeviceDeleteList
[2025-05-02 15:17:53.889] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 15:17:53.889] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}","interfaceName":"Realtek(R) Audio","name":"Lautsprecher (Realtek(R) Audio)"},"error":0},"deviceListInfo":{"devices":[{"description":"Lautsprecher","formFactor":1,"id":"{0.0.0.00000000}.{733c8362-db60-4582-871d-f42691a21602}","interfaceName":"Realtek(R) Audio","name":"Lautsprecher (Realtek(R) Audio)"},{"description":"Realtek Digital Output","formFactor":8,"id":"{0.0.0.00000000}.{ed6e4f17-c924-4063-abbd-a36a1960c20d}","interfaceName":"Realtek(R) Audio","name":"Realtek Digital Output (Realtek(R) Audio)"}],"error":0},"io":0,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:17:55.601] [info] Windows Audio Session - Device added: {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.618] [trace] Hardware agc not available - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:55.618] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"","formFactor":11,"id":"","interfaceName":"","name":""},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 15:17:55.635] [info] Windows Audio Session - DEVICETYPE_CAPTURE - Default device changed: {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.635] [debug] WAS::openDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.686] [trace] Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:55.686] [trace] Initializing with mix format. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:55.933] [info] Initialized with 2 channels in 32bit, 48kHz. - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:55.933] [trace] WAS Buffer size: 1056 - Mikrofon (Realtek(R) Audio)
[2025-05-02 15:17:55.933] [debug] WAS::openDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.933] [debug] WAS::startDevice-enter - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.934] [debug] WAS::startDevice-leave - {0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}
[2025-05-02 15:17:55.935] [trace] SoundDeviceList: {"payload":{"defaultDevice":{"device":{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"},"error":0},"deviceListInfo":{"devices":[{"description":"Mikrofon","formFactor":4,"id":"{0.0.1.00000000}.{f28b7b2f-1953-4e4a-859a-5e690cacaa1f}","interfaceName":"Realtek(R) Audio","name":"Mikrofon (Realtek(R) Audio)"}],"error":0},"io":1,"mode":"Windows Audio Session"},"type":"soundDeviceListChanged"}
[2025-05-02 16:13:55.483] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-05-02 16:26:56.567] [info] successfully downloaded revocation list for myteamspeak id
[2025-05-02 16:26:56.660] [info] successfully downloaded revocation list for accounting
[2025-05-02 17:13:56.544] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-05-02 18:13:57.608] [info] starting download for http://update.teamspeak.com/windows/x64/latest/info.json
[2025-05-02 18:27:28.465] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 18:27:28.465] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 18:27:29.418] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 18:27:29.418] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 18:27:29.430] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 18:27:29.430] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 18:27:29.434] [trace] DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
[2025-05-02 18:27:29.434] [trace] DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
[2025-05-02 18:27:30.273] [info] Notifications_Windows dtor
I’ll come back to you next week as soon as I got any news regarding this issue.
From what it looks like this is not a bug, rather not a good user experience, as when the default device gets removed, it will jump to the next available device without any notice.
If the device itself is selected then it would prompt you with a notice that the device is missing.
We now can not provide a solution for this problem.
It looks like the device has a whacky connection to the USB port or is getting disconnected from Windows due to hibernation/sleep.
