hello, i am trying to use a template my friend gave me for team speak but i dont know how to upload it image attached!
Looks like a snapshot file from yatqa.
So if you don’t have it on your computer go download it from here: https://yat.qa
After that login to your server with the serveradmin query account.
Select your server and then go to miscellaneous tab. Click the restore snapshot and then choose this file.
IMPORTANT: This will override everything you have made on your server. Everything you have made in the past will be gone. I suggest before you do anything take a backup of the database file.
Yes that is a snapshot.
The Snapshot itself is Base64 encoded and compressed with zstd .
