After the release of update #6, the application stopped opening. Reinstallation does not help, even after completely deleting the application with the deletion of all folders and registry keys, as well as the teamspeak folder in the APPData folder. Reinstalling version #5 allows you to enable the application of version #5 once, after which, after closing, the application of version #5 stops turning on similarly to version #6.After each unsuccessful opening of the application, the following message is added to the application folder in the Debug file: [0123/212836.303:INFO:crash_reporting.cc(209)] Crash reporting enabled for process: browser
[0123/212836.769:INFO:crash_reporting.cc(209)] Crash reporting enabled for process: utility
