OBS overlay for TeamSpeak5/6
I have created an OBS-Overlay, similar to the Discord in-game overlay, using the remote app feature.
This enables your audience to keep track of who is currently talking.
This OBS overlay shows all clients in your channel: who is talking, who has their microphone muted, and who is completely muted.
You can customize the overlay in the generator below. There will be more customization options in the future.
It is very easy to use, just use this generator: https://teamspeak-overlay.tealfire.de/#/generate
If there are any bugs, let me know.
looks nice i wonder if there will be overwolf app for ts5
I’ve updated the overlay to streamline the process; no need to go through the whole downloading setup.
Simply add a browser source in OBS using this URL: https://dertyp7.github.io/ts5-obs-overlay.
Make sure to have ‘remote apps’ enabled and accept the TS5-Notifications.
it is strange that this overlay does not always work in obs…
Could you be a little more specific?
  • Do you get a notification in your TS-Client, to accept the overlay?
  • Are you connected to multiple servers at once?
  • Are you using the online version with the URL https://dertyp7.github.io/ts5-obs-overlay or a local version?
  • Is the overlay connecting to the TS-Client and after a while it is disconnecting/crashing?
I receive a notification, I am connected to the same server, I use the online version… the overlay does not start in the obs
That’s weird.
What happens when you open the URL inside a Browser (like Chrome) and accept the notification in TS?
white background
The overlay now has a generator: https://teamspeak-overlay.tealfire.de/#/generate
This makes the customization of the overlay way easier.
