Orphaned registry key
The registry entry shown in the screenshot is a broken COM/CLSID registration.
It points to notification_helper.exe under the TeamSpeak install path, but the executable no longer exists.
This leaves an orphaned LocalServer32 entry under HKEY_CLASSES_ROOT\CLSID, likely from an incomplete uninstall or update.
Please consider cleaning or correcting this during uninstall/update to avoid orphaned registry entries.
Thanks for the hint, I’ll forward this to our team to evaluate.
