Package Installer not downloading Tfar
The Teamspeak is installing Tfar with adobe …Help
You mean that the add-on installer is also installing adobe on your system right?
Are you using first party installers? If not make sure that you only download from verified sources. That installer that installs unnecessary programs is probably not made from TeamSpeak, you may reach out to the developer (team) and ask them if they can help you with a cleaner installation.
