Paket loss with teamspeak 6 client, while ts3 runs fine
Hey,
I get Paket loss and a high ping with the Teamspeak 6 Client while the Teamspeak 3 Client is running fine.
Both Clients running simultaneous on the same PC and are connected to the same Teamspeak Server.
The problem is not always persistend, but it is reproducible when it is.
Server has basically zero load, same for the pc.
Can you please check with what IP / domain both clients are connected to?
Check for this specific line:
For TS6:
[DATE] [info] Connecting to resolved address ---.---.---.---
For TS3:
DATE	ClientUI	Info	Initiating connection: ---.---.---.---
Do both match each other?
Yes, of course they connect to the same ip.
I host the Server on a strong VPS.
So when the issue occured, i checked my connection and it was fine.
I then joined the same server, the same channel and i kept talking without any issues on teamspeak 3
Which server version are you using?
