Poke power permission bug
In the TS6 server I checked and verified, there’s a bug in the Poke power where it allows “Guests” by default to poke anyone in the server including Server admins, the setting by default is set as "Needed client poke power ‘75’ ", which should prevent Guest from poking even admins, but in reality they can poke anyone even admins who goes with 75 power.
I even tried to set Guests having 0 or 1 poke power, but still the needed permission is completly ignored by it… And then it should be a bug because “Needed kick, ban, and even move” are set to 25 only and those permissions are working as it should, so I guess It’s really a bug.
I just tried to reproduce your problem, but everything is working fine for me! If you want you can send me a dm with the server and I can help you
Yeah! Thanks for the help, seems the default settings just came with lots of issues, so modifying a bit did the trick.
