Problem with Avatar!
Hello, this morning I deleted the teamspeak cache I then relaunched teamspeak 3 and then I connected to my teamspeak server and the player avatar does not load there is only 1 that loaded on all others how to fix this problem?
you have understood absolutely nothing about my problem have you read my problem at least?
I will not delete the avatar of my players just because I am the only one unable to display them at teamspeak to correct this problem.
Verify your connection is not blocking the file transfer port the server uses (review the log). Ask another player on the server to clear their cache and see if they then have the same problem. If they too have this problem make sure the file transfer ports are properly forwarded to the server or allowed in the firewall. And last, if the port forwarding/firewall for the server already good, was the server moved from one location (folder/file system/server) to another maybe the loaded avatars failed to get moved with it.
Right, but if no one has changed their avatar in a while there could have been a security/networking change or server host change that make the images no longer available, but the local cache has hidden the problem until it was cleared.
With more thought: Having one avatar that works, assuming its not their own, would make me think maybe the server was moved and the files didn’t move with it and that one user changed their avatar since the move. Or, since an unaware hoster decided to free up used disk space.
Right, but some people use 3rd party firewall or one installed on network hardware that may be less application aware.
I even tried with a friend the image loads only for certain people and no error on the client and server side.
I can say that is incorrect. Server could have been changed anytime since the images were cached until the user cleared their client cache.
Proof case: TeamSpeak on their community server blocked the file transfer port for years, and didn’t clear already loaded avatars from the database. Any client that first connected with no cache for that server or that cleared their cache would have the broken avatars. While on one of my seldom used computers I still saw everyone’s avatar for years as the cache was not cleared there.
Agree that for this case more information is needed.
Windows 10 and the machine host its debian 10 linux server
noloading
Problem solved the problem was that I forgot to save the avatar before resetting my machine!
