I have problem, when i connect to some TS3 server my mic is disabled,but when i go to capture and i press begin test, i hear myself and my mic works. Also i on TS5 my mic normally works.
Check if a capture profile is selected : Self > Capture Profile.
Thanks bro, it worked
Nice to hear.
Welcome to TeamSpeak
Hi, every time when i connect again, my mic is disabled and i need to go Self > Capture Profile. I didnt have to do that before. How can i make that every time when i connect my mic is enabled ?
Using âSelfâ is temporal, just while you are connected.
Better verify that your connection has profiles assigned.
If you use âConnections --> Connectâ
or
If you use âBookmarks --> Manage Bookmarksâ
then
â> button âMoreâ and assign Capture profile, Playback profile
Maybe a Program is blocking TeamSpeak to use your mic?
