Appena mi collego al mio solito server, il microfono si disabilita e non riesco ad abilitarlo, potete aiutarmi.
1st
Translation: As soon as I connect to my usual server, the microphone is disabled and I can’t enable it, you can help me.
2nd
Let’s see!
- Is the microphone detected by your OS?
- (Are you using Windows, OS X or Linux?)
- Does it work on different servers?
- Did it work before?
Make sure you have set the correct capture profile:
neanche su altri server, ma il microfono che uso sul mio secondo pc funziona benissimo
@Gamer92000 said something, but whatever
Then it appears it’s something with microphone. Does it work outside TS? Also it would probably be helpful if you’ll tell us microphone model.
