Hi, I had problems with TS tonight which I still can’t solve at the moment.
It all started the moment I logged on; it started to disconnect and connect continuously on the server I was on, up to the point where it totally lost the connection and also connected the user with whom I used ts.
I reconnected, but unauthorized, the user I was using before. Servers empty and continues to disconnect continuously.
I can’t say what the problem is … do you have any suggestions?
Good luck.
I hope you will understand.
Please write your Problem in English, than we can help you.
magari, ma non sono capace
Please translate your Problem with Google Translator
ok… i change lenguage whit googletraslate.
