Hey freinds, my push to to talk wont work it worked at first but now wont work with my set hot key, can someone please tell me how to fix this i tried everything.
What operating system are you using?
Is TeamSpeak installed as 32 or 64bit?
Which TeamSpeak version are you using?
What do you want the hotkey to be?
Is the correct hotkey profile selected?
I want the hotkey to be the enter button and its the teamspeak 64 bit, what do you mean by operating system
What operating system are you using? - An operating system is the basic software running on your computer. It is typically either Windows, MacOS, or Linux, but others exist.
yeah i selected mutiple hotkeys? I even deleted teamspeak do you think its something in my settings
This answered none of the questions asked to identify the issue.
Please read again what Gamer92000
asked you in his posts.
