I ran a TS server years ago and now I just installed the latest 64 bit version of the server and the Client (3.6.2). So I don’t know if I am running V5 or what since the version is 3.6.2. What happened to V4 and V5? Anyhow, my needs are really simple as for now I will just have 2 or 3 people in my family using it for BF2042 game play and although I didn’t have any issues when I set it up years ago, I am confused on what permissions I should set and where. I think I need to use Channel Groups and Channel permissions but no way do they need admin access. Just mainly voice communications. Is there an easy and default way to do this or do I have to manually set individual permissions?
Thanks
Ok, So I figure creating a privilege key for a Guest would be the way to go but that begs the question, what is the difference between a “Normal” and a “Guest” privilege key?
Thanks
Ok, I am all set. Just used the Guest defaults. I guess I got confused by watching videos from years ago that were primarily showing you how not to get hosed by giving other people admin rights.
Guess someone is confused with the permissions… Don’t worry everyone got frustrated by it at some point, but the topic is too big to be cover over here, so if you want you can reach me on PM and I might give you a brief explanation how to understand permission rules.
PM Sent. ![]()
