I’m glad to see that there is finally a way to search for something in the client using the search bar or Ctrl + F. However, typing an address into the search bar makes the Quick Connect feature far too inconvenient, as you still have to switch down.
I have now become accustomed to the fact that when I connect to a server, enter the address in the search bar and ENTER. Now it is being searched. Isn’t it possible to make Quick Connect easier again, that you can use it as usual?
this is the same thing I asked for!!! +1
This topic is already on Todo. I had the same thoughts
