every one I found out that using Tools > Options > Addons > Browse online then search Radio FX and then do download it work me
@thorwe Not sure if you’ve been notified yet, but TS had an update just about 2-3 days ago and your RadioFx plugin is out of date.
@thorwe the plugin is out of date again, not working at all
Patched RadioFX version for 3.6.0: Proton Drive
I also submitted a pull request to update the main project.
Now it tells me that the minimum needs to be 26? so just wait for another update from the developer?
Yup. Pretty much only waiting. Or maybe the guy above actually made a Patch.
I do Gta5 Roleplay as an cop and I noticed when installing the Radio Fx it dose not work anymore for the new Api (26), Currently its on 23 Api
This is an SS of the issue
radio fx is still broken please fix it as soon as possible, it needs to be updated to 26 api
If you scroll up to Jun 21st, There is a highlighted text that will take you to a Patch, the patch works great
Doesn’t work…
The download that I linked above is fully functional.
