I am using TS3 v3.6.2 and would like to use the plugin RadioFX but it seems to have a problem as you can see in the picture.
Do you have a solution?
Thanks
Bruno
Try using the 3.5.6 version of the client.
https://files.teamspeak-services.com/releases/client/3.5.6/index.html
@opZ1ca Have found this in a few seconds on Github ![]()
Here is a compiled version of it Download here the Updated Radio FX Plugin
and it’s updated for the latest stable Client with Version 3.6.2 and updated for
the API 26 ![]()
How to install:
Step 1: Click on the link as I wrote above
Step 2: Click on the Green “Code” Button and select Download ZIP
Step 3: Extract the “radioFX_Compiled-main” ZIP File
Step 4: In the extracted Folder, you will see this Files:
Step 5: Click on the radiofx_plugin_win64 and install
Step 6: Enjoy your new Updated Plugin RadioFX
Greetings Rikku
Great, will try and let you know. Thanks
Great, this version works… now I need to understand how that works ![]()
Thanks again
Thanks for Feedback.
Good Luck to you
The RadioFX plugin enables you to hear clients as if they’d be talking through a walkie-talkie. Independent settings are possible for Current Server Tab, Whispers, Other Tabs and channel specific.
The RadioFX plugin isn’t tied to any game and thereby fills this gap as a generic solution.
Edit: I think this Video is good for you for the RadioFX Plugin:
