Hey, i need help with the recovery key… i dont get the window with the key and i need to sync my teamspeak. (ts and pc restart does not worked)
Please follow this little Guide:
Click on Restore Recovery Key
*Click on the Fallback Button if you don’t have your Recovery Key
ah okay thanks for your help
Is your Problem solved?
