hello i forgot my recovery key and accidentally reset it and my ids in ts3 were deleted. so when i entered ts5 i saw that my old ids were still there. but i couldn’t figure out how to export from there. i have uid’s but i couldn’t do anything with them.
You cannot export from TS5, only import is available. But you can sync it to a TS3 client and export it from there.
You cannot do anything with the UUIDs you need them exported from a client in order to use them.
The problem is that since I reset the synchronized data, the identities are not coming to ts3. It’s only available on ts5 because I synced it with ts5 before resetting the identities.
Does the TS3 Client show a synchronization error in the bottom right corner?
no
The identities are synced with TS5 but do not show in TS3 correct?
Have you tried logging out and back in on TS3?
Otherwise I don’t know anything right now to help you.
No, after synchronizing in ts5, I reset the data in ts3. and the data from the account was completely deleted. There is data only locally in ts5, but backup is not made in ts5 again.
