We are using TeamSpeak 6, no matter what settings we make, the background sounds are too loud. However, when we used Discord with the same equipment, it did not reflect any background sounds.
I think the Echo Cancellation function is not working. Or is there another setting for this? A serious problem
Could you please provide a screenshot of your audio settings?
When it comes to very loud background noises, you’ll probably need to use 3rd party software to achieve clean voice without unwanted sounds.
I have added a screenshot of the settings.
yes but when we talk with the same background volume with discord that noise is not heard. When using TS6 the background sounds come even if the person is not talking. and as I said the sounds do not come with discord. We tried many different settings but could not find a solution.
Try to set your VAD mode to Hybrid and configure the slider so that it does not trigger when no one is talking. Also try moving the noise reduction slider to the right.
Thanks for the answer but the solution you suggest is not working at all. On discord we don’t heard any background noise. But when we switch to teamspeak 6 , everyone can heard my background noise. Nothing is worked so far… You mentioned 3rd party software. Can you suggest one?
You can use krisp or NVIDIA Broadcast if you have a graphics card GeForce RTX 2060 or newer
