Hey ya kecks, I finished my soundpack in german, if you wanna download it, CLICK MEEEEEEE
Hope you like it, leave me feedback/update suggestions in the comments ![]()
Ok, letâs see.
I just listened to a few of these and love it!
I think there is a lot that could use some improvements.
Hereâs what I found:
But apart from this itâs pure gold!
Thanks for the compliments/criticism. I may release an update once I found more issues.
You can streamline the installation process by creating a package installer. This way the user only has to start the installer, instead of having to do everything manually.
Here you can find out how. Alternatively you could download this soundpack and see how it was done.
Should be done, can you try it? Download Link
The structure of the installer was slightly off.
dat keck päck.ts3_soundpack
â package.ini
â settings.ini
â sounds
â [sound files]
is incorrect.
â package.ini
â sound
â dat keck päck
â [sound files]
â settings.ini
is correct.
The package.ini contained too much information as well.
I have taken the liberty to fix the installer. https://send.firefox.com/download/d47f177a8a782df8/#ptL7UrGA2-w5srozArp7tw
Thanks dude, I just did not understand it xd
It appears the best German soundpack ever made is not quite worthy of the âMade in Germanyâ label yet, huh?
Why souldnât it be worth the label? Iâts actually made in germany xd
