增加中文支持及默认设置建议 Request for Chinese Language Support and Default Settings
亲爱的TeamSpeak开发团队,
Dear TeamSpeak Development Team,
我是一名中文用户,非常喜欢TeamSpeak的稳定性和功能。我已经在iOS和Google Play上购买了这款软件,但目前应用界面和文档缺乏中文支持,这让我们中文用户在使用时有一定困难。希望能在未来版本中增加中文语言选项,改善中文用户体验。
As a Chinese-speaking user, I really enjoy TeamSpeak’s stability and features. I have purchased this app on both iOS and Google Play, but the app currently lacks Chinese language support in both the interface and documentation, which makes it difficult for Chinese users. I hope a Chinese language option can be added in future updates to improve the experience.
此外,我有两个针对安卓端的默认设置建议:
Additionally, I have two suggestions for default settings specifically for Android:
  1. 通话时默认开启扬声器(免提),方便用户免提通话,无需每次手动切换。
    2.Enable speakerphone by default during calls*, so users don’t have to manually switch each time for hands-free use.
  2. 默认关闭息屏传感器(靠近耳朵时不自动熄屏),避免在使用耳机或手机靠近耳朵时屏幕自动关闭,影响操作体验。
    4.Disable the proximity sensor by default*, so the screen won’t automatically turn off when the phone is near the ear or when using a headset, ensuring uninterrupted operation.
我希望开发团队能重视这些建议,这对中文用户体验提升很重要。感谢团队的辛勤工作,期待未来的改进!
I hope the development team takes these suggestions into consideration, as they are important for improving the experience for Chinese users. Thank you for your hard work, and I look forward to future improvements!
Since our mobile app is due to an overhaul we are not planning to introduce new languages or features at this time.
However for our new app, we will be able to consider adding those feature requests in future updates.
Just a question, when you say “in future updates” you mean both apps are going to be available right? Or getting rid of the old one to get the newer one in the store?
Like mentioned the FR can be considered for our new mobile app.
Updating the old apps does not make much sense as they are build on old architecture.
