So for some reason my RP Soundboard is consistently louder for others than it is for me and its quite frustrating since I want to listen to it at the same noise level they’re listening to it at.
If anyone knows a fix please let me know, thanks.
Thanks.
I success this issue too
the level of volumen up to disgust for another players what listen de music in same channel of TS
use sinusbot or ts3 musicbot, btw the rp soundboard work fine to me and my friends
maybe u can try switch the codec on your channel to opus music.
which client version you and your friends are using?
channel codec?
