Screen share keep audio volume
2 suggestions:
  • After livestream ends, TeamSpeak should remember of sound level state of the last time related to person (always go default to 100%).
  • Screenshare is not that visible (recommended UI changes) - bottom screenshot.
What do you think @SYOX @LeonMarcelHD ?
@LeonMarcelHD @TS_Dennis did you review this suggestion, I don’t force anything just to random idea.
I’ll note it down.
The icon in the server tree will probably stay as it is but the audio level should stay as it has been set.
Thx!
TID: 577
