Screen Sharing Audio Recommendation
Just would like to make a quick recommendation concerning screen sharing. Please add an option in client to mute teamspeak audio during screen sharing. I either have to turn the volume off on a members stream or mute myself which neither option is optimal.
On a separate note, I did find a bug with screen sharing. If you go to user settings > OS specific, if you set “Hide TeamSpeak in Taskbar” to on minimize or both and then pop out screen sharing in to a separate window, you cannot move, resize, etc. the screen sharing window. It is essentially locked in place wherever it opens on your monitor. If you set your options to never or on close, it works as intended. I tested and replicated the bug multiple times. Just wanted to let you know.
Other than that, thanks! Just migrated over from discord becasue I am not down with the whole scan my face or give them my ID nonsense. Stay real TeamSpeak!!
