The problem that I have is that when trying to start the server it shuts down within seconds giving me 2 log files.
I have tried everything I can think of and been looking around here on the forums and on google but can’t find a solution. And therefore I am now asking here as most likely someone will have a solution to it.
I am trying to run it on a 2016 Windows VPS. And it worked around 3 months ago when I last tried.
I use the standard free license as of now for teamspeak.
Log file #1
2020-02-10 14:52:38.787184|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.11.0 (2020-01-13 08:12:37)
2020-02-10 14:52:38.787184|INFO |ServerLibPriv | |SystemInformation: Windows Server 2016 (14393) x64 (AMD or Intel) Binary: 64bit
2020-02-10 14:52:38.787184|INFO |ServerLibPriv | |Using hardware aes
2020-02-10 14:52:38.788166|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, ©TeamSpeak Systems GmbH
2020-02-10 14:52:38.788166|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
2020-02-10 14:52:38.789141|INFO |DatabaseQuery | |checking database integrity (may take a while)
2020-02-10 14:52:38.867281|WARNING |Accounting | |Unable to open licensekey.dat, falling back to limited functionality
2020-02-10 14:52:38.868255|ERROR |Accounting | |failed to register local accounting service: The file exists.
2020-02-10 14:52:38.868255|INFO |Accounting | |Licensing Information
2020-02-10 14:52:38.868255|INFO |Accounting | |licensed to : ##
2020-02-10 14:52:38.868255|INFO |Accounting | |type : No License
2020-02-10 14:52:38.868255|INFO |Accounting | |starting date : Mon Jul 1 00:00:00 2019
2020-02-10 14:52:38.868255|INFO |Accounting | |ending date : Wed Jul 1 00:00:00 2020
2020-02-10 14:52:38.869237|INFO |Accounting | |max virtualservers: 1
2020-02-10 14:52:38.869237|INFO |Accounting | |max slots : 32
2020-02-10 14:52:38.913166|INFO | | |myTeamSpeak identifier revocation list was downloaded successfully - all related features are activated
2020-02-10 14:52:40.107503|INFO | | |Puzzle precompute time: 1225
2020-02-10 14:52:40.107503|INFO |FileManager | |listening on 0.0.0.0:30033, [::]:30033
2020-02-10 14:52:40.178816|INFO |Query | |listening for query on 0.0.0.0:10011, [::]:10011
2020-02-10 14:52:40.178816|INFO |Query | |listening for query ssh on 0.0.0.0:10022, [::]:10022
2020-02-10 14:52:40.178816|INFO |CIDRManager | |updated query_ip_whitelist ips: 127.0.0.1/32, ::1/128,
Log file #2
2020-02-10 14:52:40.177840|INFO |VirtualServerBase|1 |listening on 0.0.0.0:9987, [::]:9987
2020-02-10 14:52:40.215917|INFO |VirtualServerBase|1 |stopped
Sorry for the late response @FakE
Not that I am aware of I tried to start up a brand new clean one also and get the same error.
I’m having the same issue right now. Every time the server pings the accounting server it returns the error “failed to register local accounting service: The system cannot find the file specified.”. What file is this looking for? This server has been running for a long time with no issues.
Full log:
2021-02-08 23:41:58.152274|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.13.3 (2020-12-16 14:17:05)
2021-02-08 23:41:58.153298|INFO |ServerLibPriv | |SystemInformation: Windows 10 (19041) x64 (AMD or Intel) Binary: 64bit
2021-02-08 23:41:58.153298|INFO |ServerLibPriv | |Using hardware aes
2021-02-08 23:41:58.154269|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, ©TeamSpeak Systems GmbH
2021-02-08 23:41:58.154269|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
2021-02-08 23:41:58.160279|INFO |DatabaseQuery | |checking database integrity (may take a while)
2021-02-08 23:41:58.226558|WARNING |Accounting | |Unable to open licensekey.dat, falling back to limited functionality
2021-02-08 23:41:58.237527|INFO |Accounting | |Licensing Information
2021-02-08 23:41:58.237527|INFO |Accounting | |licensed to : Anonymous
2021-02-08 23:41:58.237527|INFO |Accounting | |type : No License
2021-02-08 23:41:58.237527|INFO |Accounting | |starting date : Thu Oct 1 00:00:00 2020
2021-02-08 23:41:58.237527|INFO |Accounting | |ending date : Tue Nov 1 00:00:00 2022
2021-02-08 23:41:58.237527|INFO |Accounting | |max virtualservers: 1
2021-02-08 23:41:58.237527|INFO |Accounting | |max slots : 32
2021-02-08 23:41:58.867841|INFO | | |Puzzle precompute time: 620
2021-02-08 23:41:58.868812|INFO |FileManager | |listening on 0.0.0.0:30033, [::]:30033
2021-02-08 23:41:58.902913|INFO |Query | |Using a query thread pool size of 2
2021-02-08 23:41:58.976191|INFO |Query | |listening for query on 0.0.0.0:10011, [::]:10011
2021-02-08 23:41:58.976776|INFO |Query | |listening for ssh query on 0.0.0.0:10022, [::]:10022
2021-02-08 23:41:58.976776|INFO |Query | |listening for http query on 0.0.0.0:10080, [::]:10080
2021-02-08 23:41:58.976776|INFO |CIDRManager | |updated query_ip_allowlist ips: 127.0.0.1/32, ::1/128,
2021-02-09 00:02:37.223586|ERROR |Accounting | |failed to register local accounting service: The system cannot find the file specified.
Has anyone found a solution to this error in windows? I can find anything…
Windows 10 ltsc (1809). Free version of TS 3.13 Server.
I downloaded and extracted TS 64bit for Windows Server 3.13 yesterday. I installed the newest 64 bit client (3.5.6), and connected and inputted the privilege key. After setup, I set a password and had a friend enter successfully from elsewhere showing that the port forwarding is working just fine from my router.
The server seems to launch just fine, but seems to crash often. Uptime is anywhere from 2-60 minutes. I have rebooted and also tested the 32bit version with the same issues. Lastly i have tried running ts server as my normal user with admin, and also “run as administrator”.
Note: I have up until recently been able to run TS Server just fine with now crashes. I was forced to download the new version due to the error: “The default license has expired. Please use the latest server version.”. I extracted new server into a different folder.
Here are the log(s):
2021-02-13 18:18:59.452544|INFO |ServerLibPriv | |TeamSpeak 3 Server 3.13.3 (2020-12-16 14:17:05)
2021-02-13 18:18:59.452544|INFO |ServerLibPriv | |SystemInformation: Windows 10 (17763) x64 (AMD or Intel) Binary: 64bit
2021-02-13 18:18:59.452544|INFO |ServerLibPriv | |Using hardware aes
2021-02-13 18:18:59.483775|INFO |DatabaseQuery | |dbPlugin name: SQLite3 plugin, Version 3, ©TeamSpeak Systems GmbH
2021-02-13 18:18:59.483775|INFO |DatabaseQuery | |dbPlugin version: 3.11.1
2021-02-13 18:18:59.483775|INFO |DatabaseQuery | |checking database integrity (may take a while)
2021-02-13 18:18:59.537205|WARNING |Accounting | |Unable to open licensekey.dat, falling back to limited functionality
2021-02-13 18:18:59.537205|INFO |Accounting | |Licensing Information
2021-02-13 18:18:59.537205|INFO |Accounting | |licensed to : Anonymous
2021-02-13 18:18:59.537205|INFO |Accounting | |type : No License
2021-02-13 18:18:59.537205|INFO |Accounting | |starting date : Thu Oct 1 00:00:00 2020
2021-02-13 18:18:59.537205|INFO |Accounting | |ending date : Tue Nov 1 00:00:00 2022
2021-02-13 18:18:59.537205|INFO |Accounting | |max virtualservers: 1
2021-02-13 18:18:59.537205|INFO |Accounting | |max slots : 32
2021-02-13 18:19:00.258016|INFO | | |Puzzle precompute time: 695
2021-02-13 18:19:00.260035|INFO |FileManager | |listening on 0.0.0.0:30033, [::]:30033
2021-02-13 18:19:00.268240|INFO |Query | |Using a query thread pool size of 2
2021-02-13 18:19:00.340757|INFO |Query | |listening for query on 0.0.0.0:10011, [::]:10011
2021-02-13 18:19:00.356379|INFO |Query | |listening for ssh query on 0.0.0.0:10022, [::]:10022
2021-02-13 18:19:00.356379|INFO |Query | |listening for http query on 0.0.0.0:10080, [::]:10080
2021-02-13 18:19:00.356379|INFO |CIDRManager | |updated query_ip_allowlist ips: 127.0.0.1/32, ::1/128,
2021-02-13 18:21:14.031636|ERROR |Accounting | |failed to register local accounting service: The system cannot find the file specified.
2021-02-13 18:19:00.340757|INFO |VirtualServerBase|1 |listening on 0.0.0.0:9987, [::]:9987
2021-02-13 18:21:14.032636|INFO |VirtualServerBase|1 |stopped
