I created a server and I am the only one in it and I accidently took away the admin permissions and now I have the guest role. I do not have the password from when I created it
If you don’t have the password from serveradmin that you got during the installation, there is no other way to get it back. You will need to reinstall the server.
- List item
error id=0 msg=ok
permreset
error id=2568 msg=insufficient\sclient\spermissions failed_permid=51
use
error id=0 msg=ok
use id=10
error id=1540 msg=convert\serror
server delete 10011
error id=256 msg=command\snot\sfound
serverdelete 10011
error id=2568 msg=insufficient\sclient\spermissions failed_permid=8
servergroupaddperm
error id=1024 msg=invalid\sserverID
servergroupaddperm=caulder15
servergroupaddperm
servergroupaddperm
servergroupaddperm
servergroupaddperm
servergrouplist
hostinfo
error id=2568 msg=insufficient\sclient\spermissions failed_permid=2
serversrop
serverstop
error id=1539 msg=parameter\snot\sfound
serverperm
serverhelp
login serveradmin reset
error id=520 msg=invalid\sloginname\sor\spassword
login permreset
error id=1538 msg=invalid\sparameter
permsest 10
Edit:
Are you hosting your server on VPS or you are renting from providers?
Delete the old server and install new one.
Remember to save the query login during installation ![]()
It looks like this
I M P O R T A N T
Server Query Admin Account created
loginname= "serveradmin", password= "THHHJsn"
apikey= "BADaUohJ4KJF-eDrioZAJU_cZ_iQQB22oRx6L"
I M P O R T A N T
ServerAdmin privilege key created, please use it to gain
serveradmin rights for your virtualserver. please
also check the doc/privilegekey_guide.txt for details.
token=xItKK+TZQCuCVms3XKLUF7EBZuiuzr9Lj+vB7Tc2
I downloaded the TS Server from the website the free one. I cant find out how to actually delete the server since it tells me i have insufficient permissions
To delete the server, you have to delete all the files of the server, be it on windows or linux, and download the files again.
