Hello, my server is not visible in the server list. But it shows up when I search. It happened to itself.
How should that be possible? If it’s not listed there, you wouldn’t be able to find it yourself.
Have you set your server to appear on the server list?
Edit Virtual Server → More → Misc → Enable reporting to server list
Are all necessary ports opened?
I set it to appear in the server list. It happened this morning. I’m looking for it as a name, but it doesn’t appear on the homepage.
Do you also show all servers via the advanced filter in the server list?
I am not applying any filters. It used to appear, now it’s not. I turn the “Enable reporting server list” option off and on, it comes back. Then it goes again.
What is the name of your server?
