Hello Guys,
A Year ago, i setup a TS3 Server and did all the neccessary actions and it worked.
Now I wanted to do it again, but it doenst work.
I have a new Router and a new PC.
The PC has a fresh Windows Install and Updates, i downloaded TS3 Server and started it.
I knew from a Year ago, that Windows Firewall doenst like the Server, so i completly shut if off.
After that i port forwarded to the IP that shows in ipconfig in my PC, which is 192.168.0.156
192.168.0.156 UDP 9987 9987
192.168.0.156 TCP 30033 30033
192.168.0.156 TCP 10011 10011
MY Wan IP is 84.119.64.125, it shows it in my Router and on whatsmyip.com
I can connect from my own computer to the Teamspeak Server, when i use localhost or 192.168.0.156, but now with my IP 84.119.64.125.
Also other People cant join my TS3 Server.
For Troubleshooting i looked into Firewall from my Router.
The Only Option is Disabling it, which i dont want, but tried anyway.
Still it doenst work.
Any suggestions what may cause Problems for me?
This is the error that i Get from my second PC trying to connect to the other one.
<10:14:11> Trying to connect to server on 84.119.64.125
<10:14:16> Failed to connect to server
If theres any Information, that i need to provide, just let me know
##edit
I did some testing, without succes though.
I enabled Defender Firewall, but included ts3server.exe
I created an Account on afraid.org and setup a domain which is newmonkman.mooo.com
It points to my IP 84.119.64.125, but still doesnt work.
