Shaders fail to compile
Since the most recent rolling release of Manjaro Linux, the shaders fail to compile, leaving only an unusable window with no content. The log is pretty huge, I provided it here: ts.log - Google Drive
As rolling releases update a large number of packages, I unfortunately have no idea which one caused the problem. The systems I tested on both use an AMD Ryzen CPU with an iGPU (5850U, 7950X3D).
I tried both the AUR package and the .tar.gz directly from the TeamSpeak website.
This seems to be your problem. Either delete GPU cache (TS specific) or launch with the option stated in the bug report.
Your right, I failed to find that bug report. Deleting .cache/TeamSpeak fixed it :slight_smile:
