Hey, thanks for trying to use my theme!
Could you elaborate a little on the problems you are facing? Once the installation went through, you should see the theme in the settings under Appearance when you activate User Theme. Does it not show up there?
Hello!
I wanted to test the theme on my server with each channel having background images, problem as you can see, the images are cut off.
Is there a solution?
The default theme of TS5 has the banners left aligned, whereas my theme center aligns them.
So I guess the banners have the text on the far left and your server tree view is so narrow that it cuts them off.
So there are three possibilities to fix this:
- Make the server tree view bigger
- Move the part of the image that needs to be legible more to the center
- Remove the banner centering from the theme ( github.com )
thanks a lot!
