This has fixed my problem. Thanks!
Wow, THANK YOU! This fixed it for me too …
How did you manage to stumble across this? ![]()
It’s nice hearing that problem is going away.
But there’s still one problem…
Why isn’t this folder created automatically and need all of this to work? It shouldn’t be like that after all.
This really worked. Thanks a lot… Amazing what a missing folder can do…
The Teamspeak Team probably just has to do a very little fix. I hope they fix it asap (but enjoy your christmas time
Getting a clean install of PopOS and trying to start ts5 it will crash instantly.
After some googling I found that this is the solution.
Would be great if it could get fixed in some way.
mkdir -p $HOME/.config/TeamSpeak/Default
Thank you all for the reports and the solution!
The next client Beta38 will add a fix.
Then just make sure to update the installer/download on the beta page to that version.
Thanks, this works for me too. I hope they’ll update the download page soon.
Within next 24 hours ![]()
