Sound Control Plugin replacement or update
I was using the Volume Control Plugin by Goreki (Volume_Control_Goreki_API123_1.9.ts3_plugin), but now it makes my Client TS crash with the error 201 and it works fine if I remove that plugin. Is there another plugin that works to replace this plugin? Or is there another way to obtain the same effect using WIN10 tricks in the sound panel?
Thanks
TID: 2097
