Give us the option to place one stream on top and the other at the bottom. With two streams running, it’s impractical to place both in the top row next to each other. It wastes so much space and makes them smaller than they need to be. If I were able to place one on top and the other at the bottom, I would be able to see much more.
Huh? You can click on a stream to focus and enlarge it! Even if both were under each other, the size per stream would not really get bigger
Yes I can click on one. But then I basically can’t see the other one.
But the code already calculates the optimal arrangement to display the most content from all streams.
So in this case, placing them one above the other wouldn’t provide any benefit because the total height remains the same, if I’m correct. But I will ask our dev about this
