I’d like to suggest a cool feature that could be implemented in the permission system of TS5, and that is to make an ability to ‘Skip’ or ‘Negate’ multiple permissions at once. Example: You want to ‘Skip’ some permissions in the ‘Group -> Modify’ so you’ll just right-click ‘Modify’ and click on ‘Skip all’ and all permissions from ‘Group -> Modify’ that are added will be skipped. It won’t skip permissions that are grayed out (which wouldn’t even make sense). And the ‘Negate’ would work the same way.
I just feel like it could be a lot simplier to skip many permissions, because at the moment it’s a bit tedious.
