Hey everybody.
I use my GPU for some rendering and when my GPU is at 100% the TS5 interface is full laggy…
GPU 100%
GPU IDLE
Is possible to add option to disable Hardware Acceleration ?
Thank and nice day .
Hey everybody.
GPU 100%
GPU IDLE
--disable-gpu might do the trick. You will experience higher CPU load as a result though.
Thanks for your answer, cpu load is not a problem.
In future you add this option in gui ? Or this stay in command-line options ?
I don’t have this problem but TS need this option in GUI.
