Hello dear Teamspeak Team,
I wanted to ask you , if it’s possible to switch between microphones with hotkeys ?
Yes, as long as you have 2 or more capture profiles, each configured to the mic you want. In the Hotkey Setup Dialog window in the advanced options in the —Self— area look at the Capture Profile -> Activate Capture Profile options.
How do I do that exactly
it was helpful thanks
Thank you so much <3
