i set key binds and does not work, nothing saves even when I restart goes back to no key. even the sound notification I had to go to the folder and remove the sounds files.
I am not completely sure, but I seem to remember that if you install TeamSpeak, you get asked if you want to save stuff in “appdata” or in you “own files” (“my documents” or sth like that).
One option is recommended because you don’t have writing permissions in every directory (which leads to options not being saved).
But I am not completely sure anymore.
Perhaps someone else can confirm this ?
I recommend you to read your log files, you can find them by default in
C:\Users\YOUR_WINDOWS_USERNAME\AppData\Local\TeamSpeak\Logs\Default
