Hello, my microphone works correctly but since I’ve do the update, it don’t work currently. The mic icon says that I’ve a mic but, my friends don’t ear me. I’ve try to change my mic with 3 others but the same.
Well, this is proper link. If there isn’t some version, it means that TS haven’t uploaded it either by accident, either it’s mentioned to be like this.
And if by ”proper link” you meant link to external site not correlated to TeamSpeak, rather nobody on forum would send you that. If you want to download TS, do it from TS site.
I have not been aware that the previous version has been 3.2.2. I thought it would have been 3.5.0. which only showed an empty folder. That´s why I have been confused. I did downgrade to 3.3.2. which did solve the microphone problem. Thank you.
I will kindly ignore the assumption that I would use illegal download sites.
