hey, i wanted to ask if it is possible to use my bluetooth headphones while using teamspeak 3/5.
Because when I connected my headset via Bluetooth and am on a TS server, the sound quality (from all sound sources) is extremely bad (telephone quality)
I had the same problem, this error is not from Teamspeak but from the way your PC uses the “driver”, it thinks you are starting a phone call via Bluetooth, the quality is very bad, similar to when you are connected to the Mobiel client with airpods.
You should see if you can select your headphones with KSE
