=== Client Release 3.5.7 - 11 Jan 2021
+ Added option to automatically select channel chat tabs after connecting to a
TeamSpeak Server.
* Tweaked icons based on user feedback.
- Fixed an issue with duplicate names for cached badge icons.
- Fixed an issue where channel groups were not shown in client context menus
when an inherited group has been set.
Note for those who look and report outdated Copyrights every year.
Yes we updated them to 2021 already ;D
To enable beta updates, simply go to Tools -> Options -> Application and select “Beta” from the update channel drop down.
Once done you can check for updates using Help -> Check for Updates to receive the update.
I don’t know is my problem version number error or something. The friend list will not be saved. I add in vain as a friend, as a ban. When you close the Client, the setting is lost and the person I blocked can talk again.
