A new beta was released ![]()
- This client should fix the issue where Asus sound cards changed their settings.
- We are working on the other audio issues (AGC, user make loud noise and chirping noise) and will release another 3.6.x for these.
=== Client Release 3.6.2 - 21 Sep 2023
* Fix Asus PCIe cards issue
* Fix a client crash
To enable beta updates, simply go to Tools → Options → Application and select “Beta” from the update channel drop down.
Once done you can check for updates using Help → Check for Updates to receive the update.
Notes for this thread
- Feedback as per always is welcome in this thread
. Issues that are not related to this update belong to it’s own thread. - We suggest to place your wishes for upcoming releases in existing or new threads in the suggestion area instead of the release thread. We mention this because each update post will be closed after some days and the wish or suggestion could be lost.
- We allow ourselves to delete all the off-topic posts from this thread.
