- What is your OS? im on windows
- What is your current client version? 64 bit
- Are there any crashdumps? yes i deleted them
Bla bla […] how should we help you then?
Try this. If it works the problem is with one of your installed plugins.
how do i run it in safe mode
- Create a shortcut to TeamSpeak.
- Go to the properties of this shortcut.
- Add
-safemode(with a space at the beginning) to theTargetfield after the last"character. - Save the shortcut.
- Launch TeamSpeak through the shortcut.
ok will do
it worked will i alwasy have to run it in safe mode?
Safemode disables all plugins. So you can manually uninstall the plugins and run it normally again.
ok ty i love u sm
I can no longer start my Teamspeak, if I turn on safemode I can no longer use the plugins.
Sent: 16384/247746 bytes
Sent: 114688/247746 bytes
Error: 99
Upload finished.
Sent: 16384/231224 bytes
Error: 2
Upload finished.
Conclusion:
One of the plugins is broken and you need to remove it to use TeamSpeak without safemode.
We can not help you identify the plugin. You just need to try them one by one.
As (basically all) plugins are not developed by TS themselves you need to contact the plugin author to find a solution.
We unfortunately can not assist you any more.
yes but i cant start TS
As said: Remove the plugin that causes this and then contact the plugin author.
I have been trying to start ts3 up but i cant even in safe mode
Sent: 16384/45827 bytes
Sent: 45827/45827 bytes
Error: 201
<?xml version="1.0" encoding="UTF-8"?>AccessDeniedInvalid according to Policy: Policy expired.P56XQTGVWKCQS84KBPbTSgt76hjk7uaeMMYdKH2tDh6ZDrMgGl5gfzNCTXlO5cU3ZAwVvuC4VFvartjZxU4/7BQ2NC8=
This report does not give any information we can work with
What do you need so i can help you
See my first reply in this thread. Directly under the first post.
And please with latest log file.
Your client is spread over the Desktop
Please reinstall the client and try to use TeamSpeak 3 Client as folder.
Then try to update your sound card drivers if above did not help.
here is the most recent crashdump any help is much appreciated Dropbox - File Deleted - Simplify your life
edit-
here is the most recent crashdump, if any1 can help that would be much appreciated as this is very frustrating
Hello could you help me, ts3 crashes once opened giving me error 201 here is crashdump
