Have you any plugins installed that could trigger the crash?
hello, i have problem when i try to connect to a server i get crushed instantly without any warning or something.
i use win
Maybe you have plugins installed that could trigger the crash. Try to run the client in safemode
The start parameter -safemode will disable plugins and the client may be usable again. Now you can remove 3rd party plugins and maybe the client won’t crash when you remove the parameter again
merged by moderator
I’ve been having this problem for a long time and couldn’t find an answer anywhere. In general, when I try to connect to the server via IP, and press the “Connect” button, TeamSpeak just crashes and a window appears with the inscription “TeamSpeak 3 has completed its work” something like that, I don’t remember well. And if I click on the “Report” button, it says that an error “201” has occurred. But, if I go to the “List of servers” tab and try to go to any server from this list, then I will be able to connect, but I can’t by IP address. What to do?
What is the exact error message?
What address are you trying to connect to?
what if you try to connect via this IP?
91.134.160.232:10069
Ok, I’ll try later and post the result.
The issue is the crash and not that he can not connect.
This is why the post was moved to this thread.
@Jayson_Klemanson please read and follow this post.
https://community.teamspeak.com/t/crash-on-start/4835/2
I live in Ukraine, please tell me which hosting to dump? Which one will you prefer to watch it on?
Hello Community and Support ![]()
I have a problem with Teamspeak 3 right at startup when I try to connect to a server. The Teamspeak 3 Client crashes instantly… I have try with -safemode but doesn’t work for me…
[Crashreport]
Sent: 16384/101777 bytes
Sent: 101777/101777 bytes
Error: 201
<?xml version="1.0" encoding="UTF-8"?>AccessDeniedInvalid according to Policy: Policy expired.ENY8RV5JKST2NTEW0bUiP5rgaZB/CyC7gVOrGYUNM0cZvIXPXEDqzPabt/xA6r8UPduD6jNjkisJyrivUifX3WblQcI=
[Crashreport end]
Crashdump File download from MediaFire
thank you in advance for help
Greetings Marcel
I should note → Teamspeak 5 runs without a problem… It’s only a Teamspeak 3 problem
Thanks will forward this to our developers.
Meanwhile you may downgrade back to stable release. Just use the installer from the website and turn the beta channel off.
I have test now the Stable Version… It’s a Beta Problem =) Stable Version works and with Plugins
I don’t have this Problem on the latest 3.6.0 Beta.
All plugins that I have are working fine for me.
Here my crashdump
https://megaupload.nz/86Z2CfGeyd/ts3dump_1668024019906_zip
@mindwiper , @Evillucifer , @Giova
What CPU do you have?
AMD Athlon 64 X2 Dual Core 6000+
Since today my ts3 client refuses to start, no error, nothing visual, just nothing happening at all. So far I’ve tried:
run as admin
compatibility mode for 7/8/vista
restart
reinstall
It’s open for a second in task manager but immediately closes down again.
