Can you please describe the error you get?
It would also help if you could show us your logs
What error do you get? If you are on Windows, try starting TS3 with parameter -safemode.
Like That not wondering im from Germany
And how can i do that?
Right click on the TeamSpeak 3 Client icon and open the properties, there add the parameter after the directory.
It’s displayed in German.
If crashdumps have been created, feel free to upload them as well. You can find them in %AppData%\TS3Client\crashdumps.
You can try to put the -safemode parameter in properties and send us the crashdump log
%appdata%/TS3client/crashdumps
OMG i love you Thank youu so muchhh mannnn
You’re welcome!
Did it work for you?
Thank you
YEssssss
Small note in addition: If you use the client in safemode, your installed plugins will not work and you will not be able to install new ones.
If you need plugins, you should remove third-party plugins while in safe mode, as well as plugins you no longer need, as they may cause the crash.
Yes Saly Chat is not going
I guess that your Salty Chat plugin is causing the crash.
You have several options to solve your problem. Either contact the plugin creator and ask for help or reinstall your existing plugin or install Salty Chat from another developer.
My teamspeak crashes when I start it up I have no idea why. I’ve already tried to reinstall it and it still is doing it. Any ideas?
Are you on Windows?
If yes can you try starting your TeamSpeak 3 client using parameter -safemode?
How would I do that?
