When I use teamspeak 3 client on my Kali Linux 64-Bit (Live) I can connect to any server except hosteam servers. This is not a problem when i use the Windows OS. All my friends have the same problem. Servers that cannot be joined:
AS 51290
AS Name HOSTEAM-AS, PL
AS Prefixes
31.133.0.0/21
5.252.201.0/24
193.8.236.0/23
5.252.200.0/24
91.216.191.0/24
178.217.184.0/21
193.9.30.0/23
91.224.220.0/23
91.206.26.0/23
If it works on the same machine (or one in the same network) then it would be some configuration on the operating system / machine. For example firewalls.
Firewall is disabled. We checked on the default system settings and the problem persists. If you could, then download Kali Linux 64-Bit (Live) and check for yourself.
