TeamSpeak 3 – TCP-Based Verification for UDP Protection
In TeamSpeak 3, the main voice traffic runs on UDP port 9987.
Protecting UDP traffic is inherently difficult because UDP is connectionless and does not provide any handshake mechanism. As a result, when strict UDP protection is enabled, legitimate users often fail to join the server.
Proposed Solution
When a client attempts to connect to a TeamSpeak 3 server, a TCP-based verification step should be performed before allowing UDP traffic.
The client first sends a TCP request to a predefined port such as 443, 80, or a custom TCP port (e.g. 1234)
A standard TCP 3-way handshake is completed
After the handshake, the client’s real IP address is reliably identified
The IP address is then added to a temporary whitelist (for example, valid for 30–60 seconds)
Result
After successful TCP verification:
UDP traffic to port 9987 is automatically allowed
Legitimate users can connect without issues, even during UDP-based attacks
UDP protection becomes more stable, reliable, and effective
Advantages
More effective mitigation against UDP-based DDoS attacks
Prevents legitimate users from being blocked during server entry
Reliable IP verification using TCP
Reduced risk through time-limited whitelisting
Summary
With this approach:
Clients are verified via TCP first,
then UDP voice traffic is allowed in a controlled manner.
Final Note
So in summary, all that would be required is a small client-side update.
The TeamSpeak 3 client would simply need to send a TCP request before joining the server.
This lightweight TCP verification would allow the server or protection layer to perform a 3-way handshake, reliably identify the client’s IP address, and temporarily allow UDP traffic to port 9987.
No major architectural changes are needed — just a simple TCP request from the client, which could significantly improve UDP protection and overall user experience.
I have a very strict custom DDoS protection with checks to verify whether a user is legitimate or not in order to filter fake UDP packets. I do not have the connection error problem. You need to handle this with your DDoS protection provider.
And on my side the port is not temporarily blocked for everyone to stop a DDoS attack when one is detected because many providers do that.
