so any one experiencing issues with urls after this update it broken it only niticed it
how do i fix it for me still got the bug
also bug to report connecting to ts server mic is fully on after connecting to server ptt is hard on ptt
@TS_Chris
hope this can be fixed tooo and released soon tooo
The size doesn’t really matter all that much. Of course it should preferably be rather small in height compared to the width, as that’s how they’re displayed.
But you do have the same options as with the server banner in that you can opt to adjust the image (with or without adhering to its aspect ratio) or skip adjusting it. Adjust with aspect ratio is probably a good choice in many cases.
Not quite sure what you mean?
i connect to the ts server and im like HOT MICING on connecting to the server
Cannot reproduce.
If you disable both PTT and VAD in the Audio options, you will be continuously transmitting of course.
@TS_Chris just thought id look at settings again and it was turned on in the past but settings still work for ptt but surprise the ptt option was Turne off in the settings and im still able to use ptt as normal weird
using left ctrl still to talk even though not set in options
can we talk directly i will be on ts public in a min tooo difficult to explain
so all in all continuous transmission set but still able o ptt
Yes, there is currently a bug (as mentioned elsewhere in this thread) by which PTT becomes the current voice mode, when you press your PTT hotkey once. So whenever you press your hotkey, PTT is the active voice mode, despite not showing in settings.
This will be fixed with the next release.
i know its on the test release as i type
Hey i found a bug where the Mic not Working idk why but after some time it Stop Working here a short clip about that: https://streamable.com/r7jko
Heyy, a quick question or maybe a bug. Is it normal for Teamspeak 5 that it is after every link [/ URL] but it is sometimes very strange as in the example Screenshot by Lightshot with some links it is right in the middle and I wonder if that is wanted is o:?
No it’s a bug. Upcoming beta 21 will fix that.
Thanks for the quick editing! : D
That’s because the link was sent from a TS3 client, so yes it is normal.
