A new beta version of the client was just released.
The updater for next update to beta25 should work now when user or program path had a non-ASCII character included
We added a ||spoiler|| tag for chats and added them into the context menu when selecting text in the input field
##### Update 5.0.0-beta.24
* Updates should now be applied correctly when non-ASCII characters are found in paths
* Fix for a shutdown crash on OSX
* Context menu for free servers no longer displayed when no servers exist
* Server banner will now be reloaded after gfx interval expires
* Ban timer should now display the correct time remaining for longer bans
* Improvements to mentions (@ syntax) and a new ||spoiler|| tags feature
* Passwords are now saved for free servers
* Various minor improvements for code block formatting
* Accepting a group invite will no longer play an error sound
Known for us
The behavior of rich text editor will be changed in one of the next beta updates
We’re just uploading the installer again - will update here when that’s done. For those of you stuck on beta 19, you’ll want to reinstall from the website and then it should hopefully be fixed
Update: The installers on the beta.teamspeak.com website should now have been updated, so those of you who had ‘stuck’ updates can login and re-install (@MLS).
You only need to do this if you were still on beta 19 and couldn’t update!
There are, or should I say, were three ways: Sign in to beta(Unavailable).
Get a code from someone who got Beta codes and is willing to share one (Don’t buy them! Why you should pay when someone have these for free).
Follow TeamSpeak on facebook and twitter and count on your luck (Codes are one-time use so you need to be fast!).
Additionally, if you signed for beta and haven’t received your codes, you should contact Support.
@TS_Chris
With the Spoiler tag, upon revealing the spoiler hovering over the text will still show the small toast window but re-clicking does not re-hide the text. Is the toast window meant to stay there after reveal?
